It is currently Thu Aug 07, 2025 6:06 pm
PostPosted: Mon Jun 01, 2009 1:36 pm
The newest Luthier Tips du Jour instructional video is on Youtube. The topic is Buffing High Gloss finishes. Subtitles are available in both English and Portuguese and you can translate them into any other language by using the CC option on Youtube.
As always, comments and discussion are welcome.
Enjoy!
PostPosted: Mon Jun 01, 2009 9:11 pm
Last Name: Hodge
Excellent job again Robbie thanks. [:Y:] And I really like the loose belt idea. I do need to upgrade to the 14" buffing discs though. I think my current one's are 8" and it's a bit precarious. wow7-eyes
Bill Hodge
PostPosted: Mon Jun 01, 2009 9:57 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Another great video Robbie, I wish you had done it a month or two ago, as it would have shortened my learning curve on power buffing. I still don't really know how long to buff before recharging the wheel with compound, I probably use too much compound.
Fred
Fred Tellier
PostPosted: Wed Jun 03, 2009 8:05 am
First name: Gregg
Last Name: Cuoco
City: Albuquerque
State: NM
Zip/Postal Code: 87114
Once again an excellent video Robbie,
Thank you !!
Gregg
Gregg
PostPosted: Wed Jun 03, 2009 9:37 am
First name: Mark
Last Name: Thorpe
City: Valparaiso
State: Indiana
On the buffing compounds you use 800 grit and 1000 grit, the 800 being the medium and the 1000 being the fine as there commonly referred to. Is that correct?
Great tip by the way.
PostPosted: Wed Jun 03, 2009 9:46 am
This is correct. I only use the 800 grit for a quick buffing. This way I can quickly tell if I have any deep scratches that I didn't remove while sanding. If I do, it is better to find this out sooner rather than wait until I get to the final stages of bufing.
PostPosted: Wed Jun 03, 2009 11:00 am
First name: Mark
Last Name: Thorpe
City: Valparaiso
State: Indiana
If you do find deep scratches do you stay on that compound longer or do you go back to the hand sanding? I hope you don't mind me asking.
PostPosted: Wed Jun 03, 2009 3:32 pm
I usually go back to hand sanding. Because you already sanded to 1000 grit. If something appears it is usually less than 1000 grit.
PostPosted: Wed Jun 03, 2009 4:22 pm
First name: Mark
Last Name: Thorpe
City: Valparaiso
State: Indiana
Thanks Robbie.
PostPosted: Thu Jun 04, 2009 10:07 am
I'm confused by the grit's you are referring to. Are you saying the menzerna medium and fine are equivalent to 800 and 1000 grit paper? I would have thought they were finer than that.
...and thanks for posting that Robbie, I'm just about to try my new buffer for the first time so this is timely.
David White, Toronto
PostPosted: Thu Jun 04, 2009 11:50 am
That is correct David. I got this info years ago from the Grizzly catalogue.
PostPosted: Thu Jun 04, 2009 3:08 pm
I learned enough from your video to at least not be afraid to try....
What are your preferences for wheels? 10", 12", 16 Ply, 40 ply, flannel or muslin?
Judge
PostPosted: Thu Jun 04, 2009 4:02 pm
Judge
Glad to hear that you are going to give it a try Judge. My wheels are 12 inch ones made from flannel.
Users browsing this forum: No registered users and 40 guests
